Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Floor Rendering Problem » » » » Post: Re: Floor Rendering Problem |
Print at Oct 16, 2026, 10:00:21 AM |
| Posted by Puybaret at Mar 19, 2011, 7:31:44 PM |
Re: Floor Rendering Problem does advanced rendering plugin work on sweet home 3d v.3.1 that i using now? Yes, there was a small bug that prevented it to work correctly under version 3.0, but I fixed that in version 3.1. But you'll probably get slightly different images if you use it with version 2.6, 3.1 and 3.2 of Sweet Home 3D. If you want a total control on lighting, don't check Add ceiling lights option. Ceiling lights power depends on the area of the room. It works well in many cases, but you have a better control on lights if you add your own light sources. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 16, 2026, 10:00:21 AM |
