Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: how to restrict user to create walls at 90 degrees only, not greater and less than 90 degree, only at 90 degrees » » » » Post: Re: how to restrict user to create walls at 90 degrees only, not greater and less than 90 degree, only at 90 degrees |
Print at Sep 28, 2026, 2:22:41 PM |
| Posted by Puybaret at Mar 26, 2011, 8:38:24 AM |
Re: how to restrict user to create walls at 90 degrees only, not greater and less than 90 degree, only at 90 degrees What didn't you understand in alied answer? To be more accurate, you would have to change WallDrawingState class implementation in PlanController class. There's one value to change there and you'll get a 90° step instead of a 15° step when magnetism is on! By the way, stop flooding in the forum. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 2:22:41 PM |
