Print at Sep 24, 2026, 7:39:56 PM
Posted by hansmex at Mar 30, 2011, 9:59:48 PM
Re: Can't see anything on my floor plan!
Daryl,
If you send me the file, I'll look at it. However, I can't promise I can rescue your plan.
Did you enable the Autorecover function? (see: File --> Preferences) In that case, when starting SH3D again, it should load the file you were working on. Otherwise, check the appropriate directory to see if there is a work file:
- under Windows Vista / 7 --> C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\work
- under Windows XP and previous versions of Windows --> C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D\work
- under Mac OS X --> Library/Application Support/eTeks/Sweet Home 3D/work
- under Linux --> .eteks/sweethome3d/work
