Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Trick: elevate floors » » » » Post: Trick: elevate floors |
Print at Sep 24, 2026, 6:22:24 AM |
| Posted by hansmex at Apr 12, 2011, 11:57:40 AM |
Trick: elevate floors Hi Yesterday I thought of a simple trick to make an elevated floor, for a porch, a split-level room, or something similar. 1 - Make sure you have the plug-in CopyAsNewFurniture installed (PDF) 2 - Draw your room or house 3 - Apply your floors and give them a texture; if you need to elevate only part of the floor in a room, make sure to design the floor in two separate parts 4 - Insert a (invisible) box in your room and give it a dimension of 1x1x1 cm (or smaller) and place it in a corner where you can't see it 5 - Select the floor you want to elevate AND the box you inserted 6 - Choose Tools --> Copy as new furniture 7 - Choose Paste and the new floor will be inserted exactly on top of the old floor (with an elevation of 0.1) 8 - Delete the old floor 9 - Reposition the new floor and give it the correct elevation (in step 7 write down the coordinates of the inserted floor, and you can reposition it at the exact same spot) 10 - You can now place all your furniture on the new, elevated floor. Succes! Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 24, 2026, 6:22:24 AM |
