Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Axis of rotation » » » » Post: Re: Axis of rotation |
Print at Sep 24, 2026, 6:18:48 PM |
| Posted by HornyPotter at Apr 12, 2011, 10:45:46 PM |
Re: Axis of rotation Hey Hans, here is from the .pdf on how to install plugins... B - How to install a plug-in 1 - Windows To install a SH3P file in the plug-in folder, simply double-click the file. Hum... ok I dowsloaded the RotateHomePlugin.zip gile, double clicked on it and extracted the files. The documentation does not tell you where the extracted files should go... So a little more reading tells me How to uninstall plugins... so i found the location of the plugin folder... then i proceed to where it whould go but there is no plugins folder. the documentation does not tell me to create one. So i create the plugins folder... and i move the extracted files there... still the documentation does not tell me to go deeper in the extracted files to find the RotateHomePlugin.sh3s file and move it under the plugins directory... so yeah... well... the documentation does not tell me much... i had to try different things and i finally made it work. i like my solution better though... add objects to your plan at least 20' away from the walls, make take object so little that it will be almost invisible and then when you rotate the plan... you see the exterior wall correctly... otherwise the application takes the furthest wall and makes you see the interior like if you had your nose stuck to the wall which does not give u a good perspective. i still love SH3D! hp |
Current timezone is GMT Sep 24, 2026, 6:18:48 PM |
