Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: I can't open older projects with SH 3D in version 3.2 » » » » Post: Re: I can't open older projects with SH 3D in version 3.2 |
Print at Sep 29, 2026, 4:16:06 AM |
| Posted by Puybaret at Apr 21, 2011, 1:14:42 PM |
Re: I can't open older projects with SH 3D in version 3.2 When the program crashes, it's generally because of the 3D part. But there was no special changes between these two versions on the 3D side. Maybe you changed your computer or updated your system meanwhile. Please install Sweet Home 3D 2.0, check if you can open your files, then uninstall it, install Sweet Home 3D 3.1, try to open your files again and report if it worked or not (we'll see for Sweet Home 3D 3.2 beta version later if you don't mind). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 4:16:06 AM |
