Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: The SH3D file failed to load on the web using Sweet Home 3D Viewer » » » » Post: Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer |
Print at Sep 24, 2026, 5:38:00 PM |
| Posted by Puybaret at Apr 25, 2011, 11:26:30 PM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer If you use furnitureResourcesURLBase and texturesResourcesURLBase parameters and keep the same models and textures folders, you won't have to modify icon#, model# and image# values. From the examples you gave, it can't work because something starting with "E:/SweetHome3D-3.0-src" can't be an URL. You should add "file:///" in front of it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 5:38:00 PM |
