Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: texture bug » » » » Post: Re: texture bug |
Print at Sep 27, 2026, 6:14:06 AM |
| Posted by hansmex at May 6, 2011, 7:16:00 AM |
Re: texture bug rino, The texture renders fine every time: I tried at least 20 times without any problem. I suggest you follow Puybarets suggestion: - move a wall to check that there aren't two walls on top of each other - if two walls are on top, delete one wall - if not, move the wall back with Undo - go to the next wall - if you find a double wall, make a few renders to check if this solves the problem. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 27, 2026, 6:14:06 AM |
