Print at Sep 29, 2026, 9:18:44 AM
Posted by MaDDeePee at May 10, 2011, 5:11:45 PM
cool   Sweethome3d+Xinerama+4Screen+2GPU Setup?
Hi guys,
im unable to start Sweethome 3D with Xinerama enabled.
Im running a Xinerama setup bound with 2 Nvidia Gfx and 4 Screens connected. (Geforce GT520 & GTX560ti)
Whenever i try to start Sweethome3d, this happens:
    maddeepee@MaDWorkStatioN ~ $ /opt/SweetHome3D-3.2/SweetHome3D An irrecoverable stack overflow has occurred.
    # A fatal error has been detected by the Java Runtime Environment:
    # SIGSEGV (0xb) at pc=0x6d69d880, pid=1522, tid=1821494128
    # JRE version: 6.0_24-b07
    # Java VM: Java HotSpot(TM) Server VM (19.1-b02 mixed mode linux-x86 )
    # Problematic frame:
    # C [libnvidia-glcore.so.270.41.06+0xc8d880]
    # An error report file with more information is saved as:
    # /home/maddeepee/hs_err_pid1522.log
    # If you would like to submit a bug report, please visit:
    # http://java.sun.com/webapps/bugreport/crash.jsp
    # The crash happened outside the Java Virtual Machine in native code.
    # See problematic frame for where to report the bug.
    # Abgebrochen maddeepee@MaDWorkStatioN ~ $
I'm already using newest Gfx drivers and also tested older ones, without success. DISABLING Xinerama make me able to use that program.
So....is this a xinerama or Nvidia related problem?
Does i have to post the logfiles or is my problem located with that output?
Yours :)
