Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Viewer problems » » » » Post: Viewer problems |
Print at Oct 16, 2026, 3:48:26 PM |
| Posted by SimonAIG at May 11, 2011, 4:51:42 PM |
Viewer problems I am new to 3d and Java. I have done a little VB programming. I am having a problem with the viewer, I have a 3d project that I want to embed into my website. I have downloaded SweetHome3DViewer-3.2.1 and modified the .html file to: var attributes = {codebase:".", code:"com.eteks.sweethome3d.applet.SweetHome3DViewer", archive:jars, width:"40%", height:"40%"}; var parameters = {java_arguments:"-Xmx512m", navigationPanel:"true", homeURL:"http://80.247.0.159/3d/Full.sh3d"}; Then down loaded it with the ./lib files. When I try to open http://80.247.0.159/3d/Full.sh3d i see the Java rotating icon for 2 to 3 minutes and the a message flashes up saying opening home. Next I get a error message of ‘Can’t open home http://80.247.0.159/3d/Full.sh3d ‘ do you have any ideas. Here is the error log. basic: Applet loaded. basic: Applet resized and added to parent container basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 119670 us, pluginInit dt 14070298 us, TotalTime: 14189968 us network: Cache entry found [url: http://80.247.0.159/3d/lib/Loader3DS1_2u.jar, version: null] prevalidated=true/0 network: Connecting http://80.247.0.159/3d/lib/Loader3DS1_2u.jar with proxy=DIRECT network: ResponseCode for http://80.247.0.159/3d/lib/Loader3DS1_2u.jar : 304 network: Encoding for http://80.247.0.159/3d/lib/Loader3DS1_2u.jar : null network: Disconnect connection to http://80.247.0.159/3d/lib/Loader3DS1_2u.jar cache: Reading Signers from 4515 http://80.247.0.159/3d/lib/Loader3DS1_2u.jar | C:\Documents and Settings\Simon Brookes\Application Data\Sun\Java\Deployment\cache\6.0\0\24697800-452f1b9c.idx cache: Read manifest for http://80.247.0.159/3d/lib/Loader3DS1_2u.jar: read=139 full=1509 network: Cache entry found [url: http://80.247.0.159/3d/lib/windows/i386/java3d.jar, version: null] prevalidated=true/0 network: Connecting http://80.247.0.159/3d/lib/windows/i386/java3d.jar with proxy=DIRECT network: ResponseCode for http://80.247.0.159/3d/lib/windows/i386/java3d.jar : 304 network: Encoding for http://80.247.0.159/3d/lib/windows/i386/java3d.jar : null network: Disconnect connection to http://80.247.0.159/3d/lib/windows/i386/java3d.jar cache: Reading Signers from 4515 http://80.247.0.159/3d/lib/windows/i386/java3d.jar | C:\Documents and Settings\Simon Brookes\Application Data\Sun\Java\Deployment\cache\6.0\13\13db650d-6dd7cf27.idx cache: Read manifest for http://80.247.0.159/3d/lib/windows/i386/java3d.jar: read=342 full=342 basic: Applet initialized basic: Removed progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@1e51060 basic: Applet made visible basic: Starting applet basic: completed perf rollup basic: Applet started basic: Told clients applet is started network: Cache entry not found [url: http://80.247.0.159/3d/Full.sh3d, version: null] network: Connecting http://80.247.0.159/3d/Full.sh3d with proxy=DIRECT |
Current timezone is GMT Oct 16, 2026, 3:48:26 PM |
