Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: reconnect split walls » » » » Post: Re: reconnect split walls |
Print at Sep 24, 2026, 12:32:28 PM |
| Posted by hansmex at May 12, 2011, 4:27:21 PM |
Re: reconnect split walls Marshall, 1 - Connect two walls If you install the AdvancedEdit plug-in (see manual PDF) you can connect two walls, giving them an "elastic" connection. Corners will be closed, and if necessary beveled. 2 - (Re-)Connect split walls A split wall is still connected (see 1). You cannot make one continuous wall from two wall sections. Once a wall is split, it cannot be re-joined. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 24, 2026, 12:32:28 PM |
