Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Option to enter a wall length minus the wall thickness » » » » Post: Re: Option to enter a wall length minus the wall thickness |
Print at Sep 25, 2026, 7:35:22 PM |
| Posted by Puybaret at May 21, 2011, 2:23:45 PM |
Re: Option to enter a wall length minus the wall thickness Displaying the length this way would work only if you draw a closed convex room. What about internal walls that will be used to separate rooms in a home? What about concave rooms? What about convex rooms with angles different than 90°? There's no way to anticipate these cases and what the user will draw! An other idea I had in mind for a while was to keep the length as it's displayed, and add an other label + value that would display the length minus the wall thickness. But I can't imagine a (short) label that new users will understand without troubling them, and anyway subtracting thickness from length isn't so hard, is it? The only simple workaround I found until now was to let users create the walls around a room by double-clicking in it... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 7:35:22 PM |
