Print at Oct 3, 2026, 8:11:05 AM
Posted by workvaani at Jun 16, 2011, 1:37:46 AM
confused   Deploy extracted sh3d file in web application tomcat
I have done the following configuration:
1. In sweetHome3d applet html file, set the parameters as below:
var parameters = {java_arguments:"-Xmx512m", readHomeURL:"%s", defaultHome:"demo"};
2. In the web application - extracted folder having contents of a demo.sh3d
When I run the application I get below error - stack trace:
I have tried adding different url's like file:/// [complete path] or http:// [folder] server path but still it is not able to open the extracted home folder. Please guide???
com.eteks.sweethome3d.model.RecorderException: Can't read home from demo
at com.eteks.sweethome3d.applet.HomeAppletRecorder.readHome(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$22.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.EOFException
at java.io.ObjectInputStream$PeekInputStream.readFully(Unknown Source)
at java.io.ObjectInputStream$BlockDataInputStream.readShort(Unknown Source)
at java.io.ObjectInputStream.readStreamHeader(Unknown Source)
at java.io.ObjectInputStream.<init>(Unknown Source)
at com.eteks.sweethome3d.io.DefaultHomeInputStream$HomeObjectInputStream.<init>(Unknown Source)
at com.eteks.sweethome3d.io.DefaultHomeInputStream.readHome(Unknown Source)
... 12 more
Thanks!!,
Vaani
