Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Mirror Entire Design » » » » Post: Re: Mirror Entire Design |
Print at Sep 24, 2026, 7:00:59 PM |
| Posted by hansmex at Jun 23, 2011, 8:27:09 PM |
Re: Mirror Entire Design Andy, There are two simple ways to mirror the house: - finalize your design - choose 3D view --> Export to OBJ format - now do Furniture --> Import furniture - insert the model into a new design - modify the model and check Mirrored shape The downside of this method is that you cannot edit your design anymore. The other method is similar, but you need to have the plug-in CopyAsNewFurniture (PDF) installed. - select the part of your design that you want to see mirrored - now choose Tools --> Copy as new furniture - choose Paste and the copy will be inserted at exactly the same spot - move the copy to the side - modify the copy and check Mirrored shape - you now have the original and the mirrored copy side by side Unfortunately no method exists that allows you to mirror the original and keep editing. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 24, 2026, 7:00:59 PM |
