Print at Sep 24, 2026, 7:19:00 AM
Posted by hansmex at Jul 17, 2011, 12:34:46 AM
Re: cannot find menu or tool bar in sweet home. I would like to split walls horizontally. Fabulour program
Currey,
Is there a question here?
You cannot split walls horizontally, only vertically.
If you want to have horizontal parts in a wall, you can try several methods:
1 - Use boxes, or make a wall with a box on top of it.
2 - Use the method described in the multi-level tutorial. PDF
What you do is draw the bottom wall first. Then draw the top part and use CopyAsNewFurniture to stack it onto the bottom part.
3 - Use the method described in the roofs tutorial. PDF
In this case you draw a wall, split it vertically, then export it as OBJ, then re-import it and rotate it 90 degrees.
