Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to draw a room » » » » Post: Re: How to draw a room |
Print at Sep 24, 2026, 6:19:13 PM |
| Posted by hansmex at Jul 19, 2011, 10:48:21 AM |
Re: How to draw a room Rimvy, When drawing a room, a tool tip appears that gives the exact length of the line you are drawing, and the angle relative to the last point. This should enable you to draw with a high degree of precision. However, a mouse is a rather imprecise tool, and it can be difficult to get lengths exactly right. You can increase precision by zooming in further, so that mouse movement translates into a smaller distance. The discussion about how to draw walls and rooms is an old one, and one that has no easy solution. Consider a room surrounded by walls of three different thicknesses, a common situation in many houses (say: outside cavity walls 30 cms thick, load bearing internal walls 20 cms thick, non-load bearing internal walls 10 cms thick). Whether you draw the walls first, or the room first, you will need to do some simple calculations to correctly draw the plan. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 24, 2026, 6:19:13 PM |
