Print at Sep 29, 2026, 8:03:32 AM
Posted by Byron at Aug 1, 2011, 10:17:40 AM
Re: Plugin - Creating Objects with other Properties
Another thing I want ot mention is the following.
I do not know with which version you two are working,
but in general our version cannot be upgraded anymore which is really sad.
So, if by any chance you can use plugins or talk with emanuel puybaret about your adjustments, do it and like this what you do
can be also used to just extend SH3D funcitonality for everyone.
Also you can update the program and always use the newest version of SH3D.
2nd for generating new objects:
Besides creating the classes URDFPiece, HomeURDFPiece, etc.
(same for Gazebo classes)
If you just want to change things in the objects you need to do the following:
The key classes to modify then is:
homecontroller and furniturecatalogtransferhandler(for adding furniture)
homefurniturecontroller: here u need to add properties, add setters and getters, and modifier functions
homefurniturepanel: is what will be shown on double click.
If you check svn there should be a so called class urdf-panel
which will be displayed on the bottom.
this class you can just use and create new buttons, etc.
and
