Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Problem in Running SH3D » » » » Post: Re: Problem in Running SH3D |
Print at Oct 13, 2026, 4:14:39 AM |
| Posted by Puybaret at Aug 5, 2011, 9:22:51 AM |
Re: Problem in Running SH3D I just tried successfully under Lion with the JDK that was automatically installed. You error happens because the Java3D 1.5.2 libraries cited in java.ext.dirs are not found, then Sweet Home 3D uses the default Java3D 1.3 found in /System/Library/Java/Extensions/. As lib and lib/macosx are relative paths, this probably means they are relative to the project root in the configuration you run. Replacing these paths by absolute paths should fix the problem. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 13, 2026, 4:14:39 AM |
