Print at Oct 11, 2026, 1:28:14 AM
Posted by Puybaret at Sep 28, 2011, 4:55:21 PM
Re: Lampshade transparency
From the MTL specifications, the Ni value is for optical density or index of refraction and not transparency.
You should better play with the d value which is the transparency factor from 0 (fully transparent) to 1 (fully opaque and default value).
I'll be happy to see the results of your tests. smile
