Print at Sep 24, 2026, 9:12:20 PM
Posted by hansmex at Sep 29, 2011, 11:42:56 AM
Re: Small black square "dots" on high quality renderings
Cristian,
A large render would only be useful if you plan to print your image. Your screen can't display all those pixels. Your printer, however, has a much higher resolution.
Example:
- a 10x10 inch image on your screen can show a maximum of 720x720 (or sometimes 960x960) pixels.
- a 10x10 inch image on your printer can show easily 3000x3000 pixels when printed at 300 dpi.
So, if there are jagged edges in the screen image, they would (almost) disappear when printed.
Also, since version 3.0 the quality difference between Q3 and Q4 is much smaller than it was in earlier versions. Personally, I don't use Q4 anymore, because the slightly higher quality doesn't justify the much longer render time.
