Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Changing Scale to 1:50 (1m = 0.5 cm) » » » » Post: Re: Changing Scale to 1:50 (1m = 0.5 cm) |
Print at Oct 11, 2026, 3:19:36 PM |
| Posted by hansmex at Sep 30, 2011, 11:27:11 AM |
Re: Changing Scale to 1:50 (1m = 0.5 cm) Sue, Your question isn't very clear, but let me try to answer it anyway. 1 - When drawing your plan, you should use real-life measurements. If your basement measures 10x10 meters, draw it as 10x10 meters. Don't scale anything. 2 - When you want to print your design, scaling may become more important, especially if you don't have dimensions in your plan. Use this command: File --> Page setup --> Scale 1/50. A word of warning: Taking measurements from paper is not wise. Architectural plans always have dimensions that clearly indicate the real and correct measurements of walls, doors, etc. I advice you do the same. SH3D has a good dimension tool: use Plan --> Create dimensions or use the corresponding button on the toolbar. I suggest your use the in-built Help (use F1) to learn more on printing. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 11, 2026, 3:19:36 PM |
