Print at Oct 5, 2026, 10:16:02 AM
Posted by ChrisOfBristol at Oct 8, 2011, 6:09:32 PM
Re: print on pdf does not work in my linux box
I'm using version 3.3, Java 1.6.0_2_2. I find that if I install it using the "Ubuntu Software Centre" or by the method in your link, it just shows the startup screen then disappears. I tried running it using the advice in the FAQ "How can I disable 3D features in Sweet Home 3D" and that worked (without 3D) so I then tried removing ".no3D=true" and that works (with 3D), so I have stuck with that. The only problems I have found are the PDF printing one in this thread and that "Create Video" crashes after a while.
Great program by the way!
Chris
The command I use is:
java -Dcom.eteks.sweethome3d -jar /home/user/Documents/SweetHome3D/SweetHome3D-3.3.jar
