Print at Oct 5, 2026, 4:57:08 AM
Posted by hansmex at Oct 9, 2011, 7:59:03 PM
Re: print on pdf does not work in my linux box
Chris,
Use one of these links: Linux 32 bits or 64 bits. Both will give a TGZ-file, which is a compressed file. Normally the Archive Manager should open to unzip the file. When unzipping the file, you can specify a directory. The result will be a "main" directory with two subdirectories: one called jre1.6.0_26 and the other called lib. In the main directory you will find 10 or so text files that specify all kinds of copyright info. AND there is the small shell script I mentioned before.
I can't make it easier than that.
