Print at Sep 27, 2026, 3:19:02 AM
Posted by Puybaret at Oct 11, 2011, 5:13:39 AM
Re: 3D preview no longer centered
In aerial view mode, the view is centered on the middle of everything you added to the plan (furniture, walls, rooms...).
So either you created a big outside room for the garden for example and you should reduce its size, or you added a small item (furniture or wall) in the plan that you don't see at the scale you use. In the later case, the easiest to find it is to select Edit > Select all menu item and zoom out. Once you found the zone where it is, click on it to select it alone and delete it.
