Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: models importing w are missing their "skins" or photos/texture » » » » Post: Re: models importing w are missing their "skins" or photos/texture |
Print at Sep 25, 2026, 12:24:17 AM |
| Posted by hansmex at Oct 13, 2011, 8:43:02 AM |
Re: models importing w are missing their "skins" or photos/texture Davis, Your description of the problem is a bit strange. The model you are linking to is a SKP model, not a ZIP/DAE (=collada) or 3DS model. There is a known problem with collada models: the orientation of faces (what you call skins). Think of a sheet of paper having two faces. The render engine used by SH3D (=Sunflow) has a problem deciding which face to show. You can solve this problem by importing your model into Sketchup and then using the function Edit --> Face --> Reverse faces. You then have to use File --> Export --> 3D model to export the file as a DAE model that SH3D can use. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 25, 2026, 12:24:17 AM |
