Print at Sep 24, 2026, 5:05:30 AM
Posted by PollieXmas at Oct 18, 2011, 12:22:10 PM
Join walls
First of all thanks for a very useful program!
I am using it to get an idea of what alterations are possible on our current home.
I therefore work a lot with individual walls and wanting to move around walls. I use the split walls a lot. However, I would also like the option where it would split the wall completely. Currently I have to make a copy of the part of the split that I need and then delete the one that is still attached to the other part.
Then of course I would now want to join this wall to another wall so it moves together. Sometimes the new wall that I add to split an existing room does not join well with the existing wall making it render weird. Being able to join the wall would probably help with that too.
Finally, I would also find something like a 'format painter' very useful to transfer properties from one floor/wall to another. I find that I spend a lot of time setting up the walls, floor the way I want to have it only to realise that the room needs to change. Then it is of course much easier to simply delete the floor and double-click in the room to get a new floor, but then I have to re-do all the settings.
This tied together with the join wall feature could work well as when you join a wall it can automatically take on the format of the wall that it is joining to.
Anyway, thanks again and sorry if this feature exists or have been requested, I could not find anything with my search criteria.
Regards
Paul
