Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Join walls » » » » Post: Re: Join walls |
Print at Sep 24, 2026, 11:07:57 AM |
| Posted by hansmex at Oct 18, 2011, 1:03:56 PM |
Re: Join walls Paul, 1 - Join walls This feature exists in the form of a plug-in. You may want to read the plug-ins tutorial (PDF). It joins two walls, keeping the parts, but forming an elastic bond. 2 - Split walls The easiest way to really split walls and remove the joint (in my view) is to split a wall in three, then delete the middle part, and reconnect the remaining parts. Then, by hand, you correct the coordinates to where the split/joint should be. 3 - Paint There is a plug-in that copies colour/texture from one object to another, but I'm not sure it works on walls, because I never use it. gain, see the plug-ins tutorial mentioned above. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 24, 2026, 11:07:57 AM |
