Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 3.4 » » » » Post: Re: Sweet Home 3D 3.4 |
Print at Sep 26, 2026, 9:43:31 AM |
| Posted by hansmex at Oct 28, 2011, 7:59:14 AM |
Re: Sweet Home 3D 3.4 Emmanuel, First of all THANK YOU very much for the new beta. Long awaited by many, you've done a superb job. I've not yet had the chance to do elaborate testing, but I found a few bugs. - When I click the link in your post, Firefox 7.0.1 opens a new tab. That's all. I can click the link again, and a new tab opens again. "Ad infinitum". Is it Ubuntu 11.10? However, when I click the 3.4 b4 link on my desktop, SH3D opens with b5. - When I draw a few walls, I cannot copy them using CTRL-C + CTL-V. - ESC doesn't end the drawing of walls. - It's not possible to drag an object into the 2D window. Add to home works OK. - When I move a wall, I cannot Undo that action. - When I draw a simple house with two floors (= two layers), and then use Modify layer to increase the thickness of the ceiling and decrease the height of the walls of the top layer, there is a "strange" overlap visible in the walls, that corresponds with the decrease of wall height. This can be seen in aerial view and virtual visitor, and resembles the effect when you have two overlapping walls. - The compass has moved to the "old" position of 0,0. - When inserting furniture, no handles appear to rotate or change height. - When level 1 is active, it's still possible to delete furniture on level 0. Hans Post 09:00 hrs Edit 15:30 hrs, 16:45 hrs ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 26, 2026, 9:43:31 AM |
