Print at Sep 24, 2026, 10:31:40 PM
Posted by coldcomfort at Nov 4, 2011, 11:42:03 PM
Re: Triangular window/frame
Thanks for the detailed answer, hansmex.
I basically want to make a loft (if this is the right word) ending with a terrace under the roof, separated by a glass wall. So none of the options you described are doing it for me.
It would've been possible with a right triangle window or frame, but, as you say, that's impossible. It's only a small inconvenience.
Maybe in the future releases it will be possible to vary the transparency of independent wall units...
