Print at Sep 23, 2026, 4:31:07 PM
Posted by Puybaret at Nov 20, 2011, 8:04:12 AM
Re: Duplicating object will not release the cursor
Long import = big models = lot of memory, and from OutOfMemoryError appearing in the log, it's actually a memory problem. Even if you might find that weird, Java programs can't consume as much memory as they want. If you want to increase the max amount of memory the program can use in the downloadable version, please read the FAQ, but if I were you, I would simply forget the idea of using this model.
