Print at Sep 23, 2026, 2:32:25 PM
Posted by node105 at Nov 20, 2011, 10:46:19 PM
Re: Duplicating object will not release the cursor
<<it's actually a memory problem. Even if you might find that weird,>>
I do; it has been a very long time since I last had to reset a memory value
As I indicated, it is not only this model, but was another much smaller ( just can't recall which one).
Not as issue discarding the particular model
I am well used to flaky Java; as a filemaker developer server user
Actually 2 places in the .plist, and the existing value is not as the fq indicates (i.e. is not 1024)
<key>Properties</key>
<dict>
<key>apple.awt.graphics.UseQuartz</key>
<string>true</string>
<key>apple.laf.useScreenMenuBar</key>
<key>jnlpx.heapsize</key>
<string>NULL,536870912</string>
<key>jnlpx.offline</key>
</dict>
<key>VMOptions</key>
<array>
<string>-Xmx536870912</string>
</array>
THanks
