Print at Oct 11, 2026, 10:04:11 AM
Posted by hansmex at Nov 21, 2011, 5:47:14 AM
Re: Lampshade transparency
Bkalley,
Instead of being rude, could you ask in a friendly and polite manner what you want to know? We might be tempted to answer you...
Transparency can be obtained in several manners in SH3D.
1 - By modifying the OBJ file.
This is described earlier in this thread. It's not the easiest way, but gives you rather fine control of the results. You will have to experiment and be patient to get good results.
2 - By applying a transparent texture.
You can make a transparent texture from a PNG or GIF file, and then apply it to a part of your model. I've used these images to make several textures that I sometimes use. When using walls, you may want to coat one side of your wall with a completely transparent texture.
3 - By using an external program.
SH3D is meant for interior decorating, not as a 3D design program. You may want to use Blender, Art of Illusion or some similar program to get the desired results.
