Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: flickering textures on self-created models » » » » Post: Re: flickering textures on self-created models |
Print at Sep 30, 2026, 12:43:11 AM |
| Posted by hansmex at Dec 5, 2011, 10:14:22 PM |
Re: flickering textures on self-created models José, In the upper image, I can see a triangle that probably shouldn't be there. Most probably, it's a part of the ceiling of the room. It's there because you (most probably) created a room in a space where not all walls have the same height. Because ceilings only have one face, they are invisible (transparent) from one side, visible (opaque) from the other side. When you rotate the 3D preview, this may look like a flickering texture. To see this one-sided-ness, look at a ceiling with the virtual visitor: when looking at the ceiling from below, it's opaque, when you elevate your point of view, the ceiling seen from above becomes invisible. If this doesn't solve the problem, you may share your design, and I'll have a look at it. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 30, 2026, 12:43:11 AM |
