Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Video renderin speed low » » » » Post: Re: Video renderin speed low |
Print at Oct 15, 2026, 10:53:19 AM |
| Posted by hansmex at Dec 19, 2011, 7:47:01 AM |
Re: Video renderin speed low Clovis, Before doing a test render on your file, I made a few changes. I decreased the number of lights from 11 to 6, because that would speed up rendering, while still allowing enough light. I did the render on a computer with two cores running Ubuntu 11.10, and 2GB of RAM allotted to SH3D. No other processes were running that consumed a lot of computer time. Check this paragraph in the FAQ to learn how you can allot more memory to SH3D. How can I adjust the memory used by Sweet Home 3D? The initial estimate of SH3D was that the rendering would take +/- 1h30m; the actual rendering took +/- 1h40m.The settings were as I found in your file: Q3 at 320x240 pixels at 25 frames. My guess would be that a rendering at Q4 would take probably 4x as much time. My guess is that a machine with 4 processor cores should do the render in approximately half the time of my machine. You may want to check that - your computer uses all 4 cores - you don't have a program running at the same time that uses a lot of processor time. I have sent the modified file and the movie to your email. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 15, 2026, 10:53:19 AM |
