Print at Oct 4, 2026, 5:18:52 PM
Posted by hansmex at Dec 30, 2011, 11:59:47 PM
Re: 3D view won't select upper level
John,
To view the upper level(s) of your design, right-click in the 3D preview window and select Display all levels; this will show all levels at the same time.
If you want to see the topmost level, right-click in the 3D preview window and select Display selected level; this will display the level that is activated with the Level tabs above the 2D window, and all levels below that level. So if you have 3 levels and want to see the lower 2 levels, select Level 2. If you want to see all three levels, select Level 3.
