Print at Sep 26, 2026, 10:56:44 AM
Posted by hansmex at Dec 31, 2011, 4:54:25 PM
Re: I Need Your Help "About Service Hatches"
Vako,
What you need is a combination of a door frame and a service hatch, but than invisible. This model isn't provided, but you can make it yourself with a bit of effort.
1 - Combine 3 very thin boxes into a door frame (2 vertical, one horizontal at the top)
2 - Export to OBJ format
3 - Using a text editor, add "d 0" (see this thread) to make it invisible
4 - Now import it as furniture, and make sure you check the check box "door/window"
If you insert this model, it will function as a door frame, but because there's no floor part, the floors of two rooms will connect seamlessly.
Maybe (very maybe) I will make the model after the weekend. Now it's time for bubbles, lots of bubbles.
