Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can't run "Create Advanced Photo" » » » » Post: Re: Can't run "Create Advanced Photo" |
Print at Oct 4, 2026, 6:50:44 AM |
| Posted by hansmex at Jan 11, 2012, 1:55:01 AM |
Re: Can't run "Create Advanced Photo" Andrew, This kind of basic info can be found in the User Guide and the Help section in the program. So, let me be very brief: Create photo - you found that already. Change compass - you found that also. Modify furniture / Modify walls - gives the option to change between (Unchanged,) Matt and Shiny. Light - has been added as furniture models called Light and as (some) Lamps that carry light; both have a dial to set the light level of the individual light source. Room lights can be disabled in the Create photo dialogue. Transparency or other surface effects are not available, but you can use transparent textures. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 4, 2026, 6:50:44 AM |
