Print at Oct 6, 2026, 7:30:59 PM
Posted by hansmex at Jan 12, 2012, 2:32:05 AM
Re: Can't run "Create Advanced Photo"
Andrew,
The Matt-Shiny settings in the old plug-in were global settings, affecting everything in your design. Although they had their use during testing, they were replaced by Matt-Shiny settings for every individual wall, ceiling or furniture model.
As the word says, Unchanged means the model settings aren't changed, which may result in rather shiny models, if the model itself has "shiny" surfaces.
If you build your model with care, and spend some time refining the settings (and lighting!!), you should be able to build much better models with version 3.4 than you could with, say, version 2.6 (or even 3.0) and the plug-in.
