Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: unregular-box » » » » Post: Re: unregular-box |
Print at Sep 26, 2026, 1:33:50 AM |
| Posted by Puybaret at Jan 20, 2012, 8:42:10 AM |
Re: unregular-box The easiest way to create this kind of irregular shape would be with Art of Illusion: - click on box tool, - draw a box of any size, - select Object > Convert to Triangle Mesh menu item, - select Object > Edit Object menu item, - In the object editor, move the vertices like you want, - once done, select Export > Wavefront (.obj) menu item, - import in Sweet Home 3D the generated file. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 1:33:50 AM |
