Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Change center-position in 3D aerial mode » » » » Post: Re: Change center-position in 3D aerial mode |
Print at Sep 27, 2026, 7:03:10 AM |
| Posted by baurat at Jan 25, 2012, 6:57:21 PM |
Re: Change center-position in 3D aerial mode I think that behind the debate of centering the scene or not, (which has a partial solution by adding objects on the edge), there is a bigger drawback that is the zoom limit. As you build an environment around your house, it becomes impossible to zoom in and turn around your kitchen for exemple. That is actually the biggest issue in my opinion. I am kind of "happy" to see that someone has exactly the same problems and thoughts about this issue. ... don't hope any change to the Aerial view mode in the coming versions Well, this makes me unhappy again... So for us, there's only the hope that maybe some day Emmanuel will change his mind. Until then, I will use SketchUp for 3D navigation and see what the house looks like from different views. |
Current timezone is GMT Sep 27, 2026, 7:03:10 AM |
