Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: model based furniture export » » » » Post: Re: model based furniture export |
Print at Oct 5, 2026, 6:27:33 AM |
| Posted by Puybaret at Jan 28, 2012, 5:44:20 AM |
Re: model based furniture export Since version 3.0, it's possible to copy the 3D models and textures imported on a computer to an other one (even if it's running on a different operating system) without using the Export to SH3F plug-in. Just transfer the content of the following folder to the similar place on the other computer: - under Windows Vista / 7, C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D , - under Windows XP, C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D , - under Mac OS X, Library/Application Support/eTeks/Sweet Home 3D folder found in your home folder, -under Linux, .eteks/sweethome3d folder found in your home folder. To avoid to create the right folder on the destination computer, run Sweet Home 3D on it and change at least one preference, then quit. If you have some problems to find the previous directory, keep in mind that the system might hide it. The sub folders found in the previous directory that you may also copy are: furniture, textures, plugins and languages. The other ones are not useful for this transfer. Hope you can handle it... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 5, 2026, 6:27:33 AM |
