Print at Sep 30, 2026, 4:54:03 PM
Posted by kolar.jan at Feb 16, 2012, 2:04:36 PM
Doors depth
Hello,
can you please advise with the following problem?
I have magnetism turned on in the preferences and when I add from the standard catalogue the "Open door" with a width 900 mm to a wall with a thickness 100 mm the depth of the door automatically changes to 906.669 mm - which could be acceptable (6.7 mm difference). But when I do the same to a wall that has thickness 250 mm the depth of the door chanes to 2266.669 mm which is totally off.
Then in the 3D overview the opened door stretches way too much into the room.
Please advise.
Jan Kolar
