Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Order of levels inverted in my (Linux) version? » » » » Post: Order of levels inverted in my (Linux) version? |
Print at Sep 26, 2026, 7:44:28 AM |
| Posted by jz77f at Mar 14, 2012, 7:07:19 PM |
Order of levels inverted in my (Linux) version? The levels is a fantastic feature! Thank you! I have this problem though: I start a new project, draw a room (just a rectangle, nothing else), then add a new layer and do the same on that layer. Although I can see both rectangles under each other in the aerial view in correct order, the design view only displays the (greyed) upper rectangle when I am on the bottom level. It should be opposite, i.e., showing a level that is below, not above the currently selected one. |
Current timezone is GMT Sep 26, 2026, 7:44:28 AM |
