Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Applying a texture to a wall » » » » Post: Re: Applying a texture to a wall |
Print at Sep 30, 2026, 3:35:53 AM |
| Posted by Puybaret at Mar 17, 2012, 9:56:13 AM |
Re: Applying a texture to a wall Textures are mapped from the bottom left of each wall, meaning the bottom left of a wall and the bottom left of the texture share the same image pixels. My guess is that the height of your wall is higher than the level height and the wall spreads on multiple levels. You should make a smaller wall at the lower level, then create an other wall at the upper level. Hope this is clear enough... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 3:35:53 AM |
