Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: roof window » » » » Post: Re: roof window |
Print at Sep 27, 2026, 3:05:28 PM |
| Posted by coldcomfort at Mar 29, 2012, 12:54:41 PM |
Re: roof window @peter. I'm not sure what problem you're facing now but the procedure is pretty simple: -build the walls in the shape you want for the roof (one panel, two angled panels or even 3 with the middle one flat, as a roof window); -insert the window in the walls at the right position and change its size accordingly; -choose the color/texture for the inside and outside (roof tile texture) walls. -select it and choose 'copy as new furniture' from tools menu (assuming you installed the "copy as new furniture' plugin http://www.sweethome3d.com/pluginsUserGuide.pdf ); -after you paste the new object and delete the old one, 'export to OBJ format' from the 3D window; Now you should be able to import it as new furniture and rotate it as you need. |
Current timezone is GMT Sep 27, 2026, 3:05:28 PM |
