Print at Oct 3, 2026, 3:39:29 AM
Posted by Puybaret at Mar 29, 2012, 7:15:14 PM
Re: problem with import and texture problem
You should check how you exported your model from the modeler you use. First the faces are inverted, something you can fix with the check box at the second step of the import furniture wizard. Then, maybe you didn't generate texture coordinates or files have incorrect names (avoid spaces).
