Print at Oct 4, 2026, 8:36:46 PM
Posted by Puybaret at Apr 13, 2012, 7:07:37 PM
Re: photography level 3 and 4 problems
This may happen if the building is very very very large.
Can you check the size of your plan? From the image you posted it shouldn't be larger than 100 meter long, and the effect you reported should happen if it's larger than 500 meter.
If you work with imperial system, maybe you mixed feet and inches.
