Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Sloped Walls question » » » » Post: Re: Sloped Walls question |
Print at Oct 15, 2026, 10:13:46 AM |
| Posted by hansmex at May 14, 2012, 4:33:28 PM |
Re: Sloped Walls question If you use the above formula to calculate the slope, you can then use (in this order) - CopyAsNewFurniture (to eliminate the floor) (see plug-ins PDF), - Export to OBJ format (to export the wall segment as a model) and - Import furniture. Make sure that during importation you rotate the wall segment 180 degrees, so that the sloping side ends up at the bottom. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 15, 2026, 10:13:46 AM |
