Print at Oct 13, 2026, 11:10:12 PM
Posted by mikeycast at Jun 3, 2012, 10:20:48 PM
Re: Problem using Ant, missing classes
Thank you, and what do you think about the sql connection problem?
I've added mysql-connector-java-5.1.18-bin.jar to the libs but Ant may not include it.
Should normally Ant add the .jar I added in /lib or do I have to force it by modifying the build.xml file?
I think about this because the symptoms are the same than when I had some problems connecting to the database.
Anyway, I don't have any messages in the Console.
