Print at Oct 13, 2026, 11:12:16 PM
Posted by Puybaret at Jun 7, 2012, 1:30:26 PM
Re: Problem using Ant, missing classes
You can send me your code, but I'm not sure I'll have the time to look at it. Maybe you could show your application from Eclipse, or deliver it as an application? You can generate a Sweet Home 3D Mac OS X application with macosxInstaller Ant target, after adding the path of the missing libraries in the Classpath array of its Info.plist file. If your additional jars are in the lib directory, there should be no other changes to make!
